Metadata Patch for gdb
701
08-03-2011 05:12 AM
LakshmiSankaran
"Note:If your item is stored in a geodatabase that is accessed from a connection in either the Database Connections or Database Servers folder, there is an issue relating to upgrading metadata from these connections. Copy the database connection and paste it into a folder on your local machine. Use this copy of the connection to access the geodatabase and upgrade the item's metadata instead. This issue will be resolved in an upcoming patch."
Has this patch been released?
AletaVienneau
No, the metadata patch isn't released yet.
