Is there a way to see what domains are in use in SDE?
628
07-20-2012 07:51 AM
TimShields
Hi all,
I have inherited some SDE databases that have multiples of the same domain like domain_1, domain_2, domain_3, etc. I was wondering if there was a way to see what feature classes are using the domains so I can update the feature classes to be using the same domain instead of having multiples of the same domain.
Thanks in advance
JakeSkinner
Esri Esteemed Contributor
Hi Tim,
You could accomplish this using Python.  Here is an example:
import arcpy from arcpy import env env.workspace = r"C:\temp\python\Test.sde"  lstDatasets = arcpy.ListDatasets("*") for dataset in lstDatasets:     lstFCs = arcpy.ListFeatureClasses("*", "", dataset)     for fc in lstFCs:         lstFields = arcpy.ListFields(fc)         for field in lstFields:             if field.domain:                 print fc, field.name, field.domain
What this code does is loop through all feature classes in the 'Test' SDE geodatabase and, if a domain is present, prints out the feature class name, the field name that contains the domain, and the domain name.
JakeSkinner
Hi Tim,
TimShields
Thank you for the quick response. This was exactly what I was looking for.
Thanks again!
