Is there a tool to Recalculate Feature Extents
13590
15
01-12-2016 09:54 PM
BenVan_Kesteren1
I have hundreds of feature datasets that have incorrect XY entents (unknown reason as to why), but I am hoping to save time by automating the pressing of the 'Recalculate' button as seen below:
Does anyone know of a tool that I can run with an iterator to run over each of my feature classes???
JasonTipton
That's that infinite loop I was talking about. The tool seems to error out a lot. So I loop until it doesn't which is mostly the 1st time, but often it has to loop back a 2nd. It could be from some process trying to make a connection to the database.
The "break" after the recalculate extent will break the loop on a successful run and move on to the next feature class. Otherwise, it will disconnect all connected users and loop back around to try again.
I could have created a boolean something like...
for feature in dataList:
     succeeded = False
     while succeeded == False:
         try:
              # recalculate
              succeeded = True
         except:
              # disconnect users
And it would accomplish the same thing without the "infinite loop" and "break"
NanaDei
Hi Ben,
Are the feature classes residing in a file geodatabase or an enterprise geodatabase?
BenVan_Kesteren1
Everything resides in Enterprise GeoDB
Cheers
MelissaJarman
There is a new geoprocessing tool at 10.4 'Recalculate Feature Class Extent'
Note this tool requires an exclusive lock for it to successfully execute.
XanderBakker
Esri Esteemed Contributor
This was already mentioned by Jason Tipton  in this thread...
MikeCusi
You can also use modelbuilder to iterate through all the FC's in the FGDB that is then passed on to Recalculate FeatureClassExtent.
