Hi Ashley,
I am trying to get a single address input return from a rest geocoding service using version 10 also but using a model or script - I got the same error message you mentioned. If you have any tips or tricks or helpful items you would be willing to share it would be greatly appreciated.
Well I am using ArcGIS API for JavaScript to create my web application. I have my Geolocator published and I am able to essentially replicate this example. But I actually want to be doing batch geocoding. The only way I can think to do this with a geoprocessing tool I make in model builder that uses my address locator. I was just wondering if there is another way to do this without creating a geoprocessing tool.
How would you do this in a web service rather than in Desktop?
The only thing I can think of is the tool may be goofing on you. I don't have a 10.x version in front of me so I don't know if this has changed. In 9.3.1 or earlier, click on the tools menu, pull down to geocoding, and select Address Locator Manager. In the dialog box presented, click ADD and navigate to your service. That's how I've always done it, and that's the method I used for the screen shots in my last post.Hope this helps!
Hi there,I went ahead and added/connected to the service, in ArcCatalog by adding a GIS Server. (I added the "main page"/"service directory" http:// link, and I can see the services in my ArcCatalog - Catalog Tree, including the geocoding service I want to use. (Note this is not hosted locally, it's on a local government website somewhere). In ArcMap, I went to use the "Geocode Addresses" Tool, and for Input Address Locator, I navigated to GIS Servers\ArcGIS ............\..... GeocodeServerWhen I did so, I recieved the "000732 : <value>: Dataset <value> does not exist or is not supported" error. Does this make sense? Could it be that I am looking at the service both in ArcCatalog & ArcMap and I should close one (that's my go to solution 🙂 ) I think I'm missing the "Add Locator" step, but I'm a little lost as to how to do that...Suggestions? Thanks!Ashley
If you can add the [published] locator to an arcmap or arccatalog session you'll be able to use it just like a local locator; it may be a little slower depending on connection speeds and the server it's actually on. You'll need a connection through 'GIS Servers' in acrcatalog estblished; simply 'add address locator'. See attached image; back to front, adding a published locator from a server I maintain.Hope this helps-
Signed in members can post, follow updates, and more. New here? Register a free account.
