Installed Arc10 SP3, geocoder slows to a crawl...
2025
8
10-26-2011 03:46 AM
MarcCusumano
I have been geocoding tables of addresses in Catalog for a few months now with great success. The process has been very quick. However, after recently installing SP3, often times the process will run like normal but then slow to a crawl after a few seconds.
The table, reference data, and address locator are all within a file geodatabase on a brand new SSD drive.
BradNiemand
Have you tried to copy the locators out of the FileGDB and into a folder instead?  This would remove geodatabase operations from the equation and help to get to the bottom of the issue.  Also, can you provide me with your data?
Brad
MarcCusumano
No I've not tried copying the locator into a folder. The operation from this morning is still running but once it's done I'll try that. I won't be able to provide you with the data as it is confidential, but thanks for the help anyway.
MarcCusumano
Has anybody else been experiencing this issue? Even copying the table to a .dbf and the reference data into a shapefile outside of a file geodatabase the process is very slow, often requiring up to 48 hours to geocode a reasonable number of addresses (<200K). The process is always run on either a new SSD or a RAM Disk.
I even got the MultiProcessGeocode python script running and it is still taking forever. Before SP3 this process would take no longer than an hour...
BradNiemand
Did you try to copy your locator out of the FGDB and into a folder as well?
Brad
MarcCusumano
Yes I had the table in a .dbf, reference data in a shapefile and the address locator inside a folder.
BradNiemand
Would it be possible to get data from you?
Brad
ErikDavis
Same problem here.  Any resolution to this issue?
ThomasKonzel
Anyone find a solution to this issue?  I've been searching the support pages but can't find anything relevant; I think it has to do with the Service Packs, but I can't be sure.
