In Field Calculator 1 To 9 Loop Numbers
1861
01-31-2017 11:16 AM
NeeleshSonekar
I have a field name gfdd i want to fill  A to I in loop till end.
Like This
A B C D E F G H I A B C D E F G H I A B C D E F G H I A B C D E F G H I....................................................
And then i want to combine Map_ to gfdd in different field :
Like This :
Map_                    gfdd                    Test
46K1                        A                    46K1 A
46K1                        B                    46K1 B
46K1                        C                    46K1 C
46K1                        D                    46K1 D
46K1                        E                     46K1 E
46K1                        F                     46K1 F
46K1                        G                    46K1 G
46K1                        H                    46K1 H
46K1                         I                     46K1 I
46O1                        A                    46O1 A
46O1                        B                    46O1 B
JoshuaBixby
MVP Esteemed Contributor
Combining the two fields, once you have them, if fairly straightforward.  For generating the gfdd field, the following should work using the Python parser:
Pre-Logic Script Code:
from itertools import cycle
rot = cycle(chr(i) for i in range(65,74))
def next_letter():
    return next(rot)‍‍‍‍
Value:
next_letter()
NeeleshSonekar
Thank you Very Much............Very Helpful For Me.................
