I think I broke the whole thing! Please help!
4239
04-07-2015 03:13 PM
BrendaCarter
I downloaded some files from the Species Richness program.  They are supposed to be grid files and the directions say to use Spatial Analyst to convert them to grid. Yes, I have spatial analyst.  Yes, it is activated however; I am not finding what I am supposed to use. I am sure someone knows what to use.  Help!The files that were downloaded were the entire richness file for the county:
dblbnd.adf
hdr.adf
log
metadata.xml
prj.adf
sta.adf
vat.adf
w001001.adf
w001001x.adf
Please point me in the right direction... or give me another alternative. I am on ArcGIS 10.2.
Tags (1)
OwenEarley
These files are already in ArcInfo grid format so you shouldn't need to convert them: 30616 - What is the file structure of an Arc/INFO Grid?
The Grid format relies on a directory structure where a workspace contains one or more grid directories. The workspace should also contain an info directory. I am guessing that something has gone wrong with the directory structure as Arcmap should be able to load the grid format.
I would suggest looking at the original download to see if the entire workspace is there or contacting the data provider to get the workspace - as the Info subdirectory contains several files which maintain certain information about the grid.
This ArcGIS Help 10.1 page has more information on the format.
GRID directory
There are a number of files that can be stored in a GRID's subdirectory. Not all of them are necessary for the GRID to display. They can be stored in one of three storage types, INFO format, ASCII format and binary format.
dblbnd.adf
- The boundary file contains the minimum and maximum x,y coordinates for a grid
- INFO format
hdr.adf
- The header file contains information about the GRID's cell resolution, type (integer or floating point), compression, and tile information.
- binary format
log
- The log file contains a history about the creation of and alterations to a GRID.
- ASCII format
prj.adf
- The projection file stores the known map projection information of the GRID. It is optional.
- ASCII format
sta.adf
- The statistics (minimum, maximum, mean, and standard deviation) of the cell values.
- INFO format
vat.adf
- The value attribute table (VAT) stores the the attribute data associated with the zones of the grid. The vat.adf can only exist for integer GRIDs.
- INFO format
w001001.adf
- Stores the value of each cell in the first (base) tile of the GRID.
- If the GRID is floating point, the values are single precision.
- binary format
w001001x.adf
- Stores the index for the blocks in the tile.
- binary format
SepheFox
Ooops! Sorry Owen, it looks like we posted at the same time!
BrendaCarter
Thank you so much!  I will definitely try this and see what happens.  I am on the east coast and will try it first thing in the AM.  Hopefully I was just a bit anxious about this process and went a little to far into the files.  I did notice that there is an info file downloaded as well.  No corruption of the files, just an eager old school user doing new school things.
SepheFox
Hi Brenda, not to worry. I'm sure nothing is beyond repair--you can always download the data again. I opened your attached zip, but it only contained the file hdr.adf. Where exactly did you go to download the data, and what county is it for? In the meantime, you might read up on the grid format here:
ArcGIS Desktop Help 9.2 - About the ESRI grid format
BrendaCarter
Hi there... thank you so much for your quick response.  I am on the east coast and was just a bit to eager.  I will try the suggestions I received first thing tomorrow morning!  I think I fried my brain worrying today.  Please know that each of you are much appreciated!
