I need some help figuring out the best process to go about selecting multiple unique values from a feature layer table.
2118
02-14-2020 07:43 AM
JamesBushOpelika
This is a basic thing I should know how to do, but I am a bit rusty. I want to select some polygons in a table by many unique values. I have a .xls table with the values I need to pull. and a matching attribute field in my feature layer table. What is the best way to select these polygons from my feature table?
James Bush
jabush@opelika-al.gov
DavidPike
MVP Notable Contributor
As Dan suggests, a table join would achieve this. You could also use a search cursor to append matching values to an empty list and then use select by attribute on the FL.
E.g. object_id_list = [1,2,3]
query = "OBJECTID in (1,2,3)"
Selectbyattribute(...
DanPatterson_Retired
Do you want to Join the tables?
Join Field—Data Management toolbox | Documentation
JamesBushOpelika
I don't believe so? I do not want to add anything to my feature layer. I just want to select multiple fields from the feature table based on another spreadsheet.
James Bush
If you want to select one with the other, then they need to be joined.... the features aren't relevant, the tables are.  The are other "join" tools in the help topics that do similar things but the end result is the same... joined tables
DavidPike
JamesBushOpelika
This worked fine! Thanks, guys!  A bit out of touch on the basics this Friday morning. . . . .
Cheers!
James Bush
