This probably comes a bit late but as I was looking for a similar solution I thought I'd share one just in case it may help someone in the future.
In Model builder use the spatial join tool with census blocks as in the input table and the points as the join table (make sure that you select a ONE TO MANY relationship).
You should then have multiple IDs for the polygons with even more for the points.
You can then use the Frequency tool to sum up the stats from the points that are in the polygons. There will be a join count attribute and this can be used in the statistics box when summing.
