How to set datasource of a layer in ArcMap to an encrypted personal geodatabase?
1647
08-24-2011 11:00 PM
dgesridgesri
Greetings,
Kindly note the following specifications of the products I`m using:
[INDENT][INDENT]
  • ArcMap 9.3
  • MS Access 2007
[/INDENT][/INDENT]
I have 3 layers in my mxd (ArcMap93) that read their sources from a Personal Geodatabase (access2007). Later on, I set a password to this PGDB for security issues.
Then when I opened the ArcMap, I found that the layers missed their datasources. I tried to set their datasources from that PGDB but I couldn`t connect to it and the following pop-up message shown:
"Failed to connect to database. The user and/or password is invalid. Not a valid password."
Is there a way to set a layer datasource in ArcMap to a PGDB that is encrypted with a password?
Thanks in advance for any try to help or advise....
CraigGillgrass
No, ArcGIS does not support working with password protected  personal geodatabases, please see this KB article:
http://support.esri.com/en/knowledgebase/techarticles/detail/34871
dgesridgesri
Thanks Mr. Craig Gillgrass...
You have provided me with the perfect answer that could save my effort and my time....
