The fastest way to do this would be to recreate the replica:1. Unregister the replica from each geodatabase2. Delete the feature class in the child geodatabase3. Replicate the data from the parent to the child geodatabase again
But won't step #2 delete the features added to the child by the field walker?Before you delete the child feature class, may I suggest you make a comparison of the parent to the child. Make a spatial selection of everything in the child that is the same in parent; then switch the selection of the child, and you should have just the field walker additions. Write those to a feature class so you can load them or otherwise get them into the parent.Hope this helps-
Thanks JS and jborgion. jborgion you're right, on step #2 it will delete everything that field walkers captured, which is not what we want. The idea is to run this daily check automatically at the background. Probably can build a model based on your suggestion. However, then it's really no need to use database replication. I thought this (restore the deleted records to Child) could be easily done by Database Replication, as it assigns a GlobalID to each record in the parent, then it shouldn't too hard to compare the two and transfer whatever is missing from the parent to Child.
Signed in members can post, follow updates, and more. New here? Register a free account.
