How to create SQL server database primary data file (*.mdf)?
2413
07-10-2010 07:33 AM
JamalNUMAN
Legendary Contributor
In case I have a file geodatabase, how to convert it to Sql server database (*.mdf) so that it can be attached to the database server
Please, see the attached images that shows my question
Jamal Numan
KimPeter
Jamal,
The .gdb file (file geodatabase) cannot be directly converted to a .mdf file (SQL Server database file).  Instead, create a new geodatabase on the database server, then import or copy and paste the data from the file geodatabase to the geodatabase on the database server.
Regards,
-Kim
JamalNUMAN
Jamal,
Regards,
-Kim
Thank you for the answer Kim.
Is this practical?
i don't understand why we cann't add (connect) our file geodatabase to the server directly without the need to have MDF file or even to import the data into a new geodatebase?
regards
Jamal
Jamal Numan
VinceAngelo
Esri Esteemed Contributor
File geodatabase is an Esri storage format.  It has nothing to do with Microsoft's SQL-Server
database structure.  They are incompatible, in the same way that diesel fuel can't be used
by a gasoline engine.
- V
JamalNUMAN
- V
You are right!
from a user point of view, it is much easier for me to just connect the file geodatabase to the server so that many users can edit the data according to the permissions and privileges given.
as the sql server doesn't work this way, we need each to create a new goedatabse on the server then to copy and past the data from our file geodatabase to that created  one on the server! no direct connect can be made!
I'm wondering what should i do if i need to expose my file geodatabse (saved on my hard disk) for edits through the server such that many users can edit this data concurrently, then which solution may ArcGIS offer for this case?
any suggestions?
regards
Jamal
Jamal Numan
