How to check if every segments of a road have the same directions?
5831
17
11-02-2017 03:35 AM
ZenekS_
I’m attempting to make a linear referencing. It’s a polyline M layer (with lengths along every line)  of forest roads . Every road (unique road number) consists of 1, 2 or more segments. In the attribute table I have a field with segment_id (unique in the layer) and a field with the road_number (many segments can have the same road_number). The layer is sorted ascending by segment_id and road_number.
The problem is – how to check if every segments of one road_number have the same direction. Maybe the solution is to calculate distance for end point and start point of subsequent segments in every road_number (but not for first and last segments – only the middle segments). When the distance if more than 0 – it will be an error. But how to calculate it?
Thanks for any suggestions how to solve this.
XanderBakker
Esri Esteemed Contributor
You could try this. It will take the input fields to the output featureclass and add a field "FlipCase" that will hold "Flipped" when the polyline was flipped. However, the M values are not reversed for each point. Are the M values length values?
def main():
    import arcpy
    import os
    # input fc and name of field containing route name
    fc = r'C:\GeoNet\RoadDirection2\test.gdb\roads_m'
    fc_out = r'C:\GeoNet\RoadDirection2\test.gdb\roads_m_corr7' # output fc
    fld_name = 'RouteName'
    fld_id = 'Segment_ID'
    fld_case = 'FlipCase'  # stores info on correction feature
    tolerance = 10 # tolerance for searching connecting segments for same route
    # sr
    sr = arcpy.Describe(fc).spatialReference
    arcpy.env.OverwriteOutput = True
    # create dictionary of data
    dct_routes = {}
    dct_seg_id_oid = {}
    dct_oid_seg_id = {}
    flds = ('OID@', 'SHAPE@', fld_name, fld_id)
    with arcpy.da.SearchCursor(fc, flds) as curs:
        for row in curs:
            dct_data = {}
            oid = row[0]
            polyline = row[1]
            route_name = row[2]
            seg_id = row[3]
            dct_seg_id_oid[seg_id] = oid
            dct_oid_seg_id[oid] = seg_id
            if route_name in dct_routes:
                dct_data = dct_routes[route_name]
                dct_data[oid] = [polyline, seg_id]
            else:
            dct_routes[route_name] = dct_data
    # supporting dct with oid and geometry
    dct_oid_geom = {r[0]: r[1] for r in arcpy.da.SearchCursor(fc, ('OID@', 'SHAPE@'))}
    # determnine first segment of route based on segment id
    dct_start_seg_id = {}
    for route_name, dct_data in sorted(dct_routes.items()):
        seg_ids = [s[1] for p,s in dct_data.items()]
        dct_start_seg_id[route_name] = min(seg_ids)
    # trace route from staring seg_id to end
    lst_flip_oid = []
    lst_candidates_todo = []
    lst_multi_candidates = []
    dct_route_order = {}
    for route_name, seg_id in sorted(dct_start_seg_id.items()):
        route_order = [seg_id]
        print "trace:", route_name, " starting @", seg_id
        dct_start_pnts = CreateDictionaryStartOrEndPoints(dct_data, "start")
        dct_end_pnts = CreateDictionaryStartOrEndPoints(dct_data, "end")
        oid = dct_seg_id_oid[seg_id]
        start_pnt = dct_start_pnts[oid]
        end_pnt = dct_end_pnts[oid]
        lst_processed = [oid]
        lst_todo = [o for o, lst in dct_data.items() if o != oid]
        while len(lst_todo) > 0:
            print "lst_processed:", lst_processed
            # get candidates for end point of line
            oid_cand_end, start_end_end, dist_from_end = GetCandidate(end_pnt, dct_start_pnts, dct_end_pnts, lst_todo, tolerance)
            print " - GetCandidate 1:", oid_cand_end, start_end_end, dist_from_end
            # get candidates for start point of line
            oid_cand_start, start_end_start, dist_from_start = GetCandidate(start_pnt, dct_start_pnts, dct_end_pnts, lst_todo, tolerance)
            print " - GetCandidate 2:", oid_cand_start, start_end_start, dist_from_start
            # check is there are candidates
            if dist_from_start == 9999 and dist_from_end == 9999:
                # no candidates
                print" - no candidates!"
                lst_candidates_todo.extend(lst_todo)
                lst_todo = []
                oid_found = None
            elif dist_from_start == dist_from_end:
                # two candidates with same score, error!
                print " - two candidates with same score, error!"
                lst_multi_candidates.append([oid_cand_end, oid_cand_start])
                lst_todo = []
                oid_found = None
            elif dist_from_start < dist_from_end:
                # candidate is at start of line, requires flip of current oid
                print " - candidate is at start of line, requires flip of current oid"
                if start_end_start == "end":
                    # also candidate need to be flipped
                    print " - current start connects to candidate end, also candidate need to be flipped"
                    print " - adding candidate oid ", oid_cand_start, " to flip list"
                    lst_flip_oid.append(oid_cand_start)
                if not oid in lst_flip_oid:
                    lst_flip_oid.append(oid)
                    print " - adding current oid ", oid, " to flip list"
                oid_found = oid_cand_start
            else:
                # candidate is at end of line, OK
                if start_end_end== "end":
                    # current end connects to candidate end, candidate need to be flipped
                    print " - current end connects to candidate end, candidate need to be flipped"
                    lst_flip_oid.append(oid_cand_end)
                    print "   - adding candidate oid ", oid_cand_end, " to flip list"
                oid_found = oid_cand_end
            if oid_found != None:
                start_pnt = dct_start_pnts[oid_found]
                end_pnt = dct_end_pnts[oid_found]
                lst_processed.append(oid_found)
                route_order.append(dct_oid_seg_id[oid_found])
                lst_todo.remove(oid_found)
                oid = oid_found
            print "lst_todo", lst_todo
            print "lst_flip_oid", lst_flip_oid
        dct_route_order[route_name] = route_order
        print
    print "lst_flip_oid        :", sorted(lst_flip_oid)
    print "lst_candidates_todo :", sorted(lst_candidates_todo)
    print "lst_multi_candidates:", lst_multi_candidates
    for route_name, route_order in sorted(dct_route_order.items()):
        print " - Route:", route_name, "  seg id order:", route_order
    # create output featureclass
    ws, fc_name = os.path.split(fc_out)
    arcpy.CreateFeatureclass_management(ws, fc_name, "POLYLINE", fc, "ENABLED", "DISABLED", sr)
    arcpy.AddField_management(fc_out, fld_case, "TEXT", None, None, 50)
    flds_in = [fld.name for fld in arcpy.ListFields(fc)]
    flds_out = [fld.name for fld in arcpy.ListFields(fc_out)]
    flds_in.remove('Shape_Length')
    flds_out.remove('Shape_Length')
    fld_geom = arcpy.Describe(fc).ShapeFieldName
    fld_oid = arcpy.Describe(fc).OIDFieldName
    flds_in[flds_in.index(fld_geom)] = 'SHAPE@'
    i_oid = flds_in.index(fld_oid)
    flds_in[flds_in.index(fld_oid)] = 'OID@'
    flds_out[flds_out.index(fld_geom)] = 'SHAPE@'
    flds_out[flds_out.index(fld_oid)] = 'OID@'
    fld_geom = 'SHAPE@'
    fld_oid = 'OID@'
    cnt = 0
    with arcpy.da.InsertCursor(fc_out, flds_out) as curs_out:
        with arcpy.da.SearchCursor(fc, flds_in) as curs:
            for row in curs:
                cnt += 1
                if cnt % 100 == 0:
                    print "Processing feature:", cnt
                oid = row[i_oid]
                polyline = dct_oid_geom[oid] # row[i_shp]
                if oid in lst_flip_oid:
                    case = "Flipped"
                    polyline_out = FlipPolyline(polyline)
                else:
                    case = "OK"
                    polyline_out = polyline
                row_out = []
                for fld_name in flds_out[:-1]:
                    row_out.append(row[flds_in.index(fld_name)])
                row_out.append(case)
                row_out[flds_out.index(fld_geom)] = polyline_out
                print row_out
                tpl_row = tuple(row_out)
                curs_out.insertRow(tpl_row)
def FlipPolyline(polyline):
    print "before:", polyline.length
    vertices = []
    for part in polyline:
        for pnt in part:
            vertices.append(pnt)
    polyline_out = arcpy.Polyline(arcpy.Array(vertices[::-1]),
                polyline.spatialReference, False, True)
    print "after :", polyline_out.length
    return polyline_out
def GetCandidate(end_pnt, dct_start_pnts, dct_end_pnts, lst_todo, tolerance):
    # return oid_cand_start, start_end, dist_from_start
    dist_min = 9999
    oid_min = None
    type_min = None
    for oid, pnt in dct_start_pnts.items():
        if oid in lst_todo:
            dist = GetDistance(end_pnt.X, end_pnt.Y, pnt.X, pnt.Y)
            if dist < tolerance:
                if dist < dist_min:
                    dist_min = dist
                    oid_min = oid
                    type_min = "start"
    for oid, pnt in dct_end_pnts.items():
        if oid in lst_todo:
                if dist < dist_min:
                    dist_min = dist
                    oid_min = oid
                    type_min = "end"
    return oid_min, type_min, dist_min
def GetDistance(x1, y1, x2, y2):
    import math
    return math.hypot(x2-x1, y2-y1)
def CreateDictionaryStartOrEndPoints(dct_data, start_or_end):
    dct_pnts = {}
    for oid, lst in dct_data.items():
        polyline = lst[0]
        if start_or_end == "start":
            dct_pnts[oid] = polyline.firstPoint
        else:
            dct_pnts[oid] = polyline.lastPoint
    return dct_pnts
if __name__ == '__main__':
    main()
XanderBakker
The are many ways to validate if there are segments with the wrong direction. For instance manually, by applying a symbology that includes line decoration:
Which will show you where you have problems in your data:
You can also create end and start points in separate featureclasses form the lines using Feature Vertices to Points:
And symbolize those:
You can also apply hatching (About displaying hatches—Help | ArcGIS Desktop ) to validate the M values of the road (are they continuous):
Or you can analyze the start and end featureclasses with a Generate Near Table and validate where you have start points without end point (although you would need to exclude the start and end points of a route.
Or create routes to see if the routes makes sense when you apply the M values of the road segments.
JayantaPoddar
Symbology > Arrow at End.
Think Location
ZenekS_
Thank you for your answers and screenshots. Of course these solutions are good and I can apply them to my dataset.
But how to calculate (maybe in Python) distance for end point and start point of subsequent segments in every road_number (but not for first and last segments – only the middle segments) ? When the distance is more than 0 – it will be an error.
XanderBakker
You can script this, but this can get pretty complex. I did something in the past. Let me dig into my archive and see if I can share some code.
XanderBakker
See below some sample code that could be a start:
def main():
    import arcpy
    fc = r'C:\GeoNet\RoadDirection\test.gdb\roads_m'
    tolerance = 1
    # sr
    dct_routes = {}
    flds = ('OID@', 'SHAPE@', fld_name)
        for row in curs:
            dct_data = {}
            oid = row[0]
            polyline = row[1]
            route_name = row[2]
                dct_data[oid] = polyline
            else:
    # determnine first segment of route based on minimum M value
    dct_possible_errors = {}
        print "dct_possible_errors", dct_possible_errors
        oid = GetFirstSegmentOfRouteOnMvalue(dct_data)
        print
        print " - GetFirstSegmentOfRouteOnMvalue:", route_name, oid
        print route_name
        print " - len:", len(dct_data.keys())
        print " - oid:", oid
        # start connecting segments
        lst_todo = [o for o in dct_data.keys() if not o in lst_processed]
        while len(lst_todo) != 0:
            print " - lst_processed:", lst_processed
            print " - lst_todo:", lst_todo
            oid_near_end, dist_near_end, type_near_end = FindPointsNearEnd(oid, "end", dct_start_pnts, dct_end_pnts, lst_processed)
            print " - FindPointsNearStartorEnd-end  :", oid_near_end, dist_near_end, type_near_end
            oid_near_start, dist_near_start, type_near_start = FindPointsNearStart(oid, "start", dct_start_pnts, dct_end_pnts, lst_processed)
            print " - FindPointsNearStartorEnd-start:", oid_near_start, dist_near_start, type_near_start
            from_part = "end"
            to_part = "not set"
            if dist_near_start < tolerance:
                print "   - connect to start is option..."
                print "   - oid to connect to:", oid_near_start
                to_part = "start"
                print "ERROR possible flip line case"
            if dist_near_end < tolerance:
                print "   - connect to end is option..."
                print "   - oid to connect to:", oid_near_end
                to_part = "end"
            print "    - from - to: ", from_part, " - ", to_part
            if to_part == "end":
                print "from_part is start, possible ERROR flip case!"
                lst_todo.remove(oid_near_end)
                lst_processed.append(oid_near_end)
                oid = oid_near_end
                print " - ERROR is end, Flip!:", oid_near_end
                if route_name in dct_possible_errors:
                    errors = dct_possible_errors[route_name]
                    errors.append(oid)
                    dct_possible_errors[route_name] = errors
                else:
                    dct_possible_errors[route_name] = [oid]
                print " - added:", route_name, oid
            elif to_part == "start":
                print "to_part is end, OK"
                lst_todo.remove(oid_near_start)
                lst_processed.append(oid_near_start)
                oid = oid_near_start
                print " - OK is start        :", oid_near_start
            else:
                print "no candidates available in tolerance"
                print " - still to do:", lst_todo
                lst_todo = []
    print
    for route_name, errors in dct_possible_errors.items():
        if len(errors) > 0:
            print route_name, errors
def FindPointsNearStart(oid, start_or_end, dct_start_pnts, dct_end_pnts, lst_exclude):
    else:
    dist_min = 9999
    oid_min = -1
    type_min = "not set"
    # determine distance bewteen point and start of others
    for oid_i, pnt_i in dct_start_pnts.items():
        if not oid_i in lst_exclude:
            dist_i = GetDistance(pnt.X, pnt.Y, pnt_i.X, pnt_i.Y)
            if dist_i < dist_min:
                dist_min = dist_i
                oid_min = oid_i
                type_min = "start"
    return oid_min, dist_min, type_min
def FindPointsNearEnd(oid, start_or_end, dct_start_pnts, dct_end_pnts, lst_exclude):
    else:
    dist_min = 9999
    oid_min = -1
    for oid_i, pnt_i in dct_end_pnts.items():
                dist_min = dist_i
                oid_min = oid_i
                type_min = "end"
def FindPointsNearStartorEnd(oid, start_or_end, dct_start_pnts, dct_end_pnts, lst_exclude):
    else:
    dist_min = 9999
    oid_min = -1
                dist_min = dist_i
                oid_min = oid_i
                type_min = "start"
                dist_min = dist_i
                oid_min = oid_i
                type_min = "end"
    import math
    dct_pnts = {}
    for oid, polyline in dct_data.items():
        else:
    return dct_pnts
def GetFirstSegmentOfRouteOnMvalue(dct_data):
    m_min = 99999
    oid_min = -1
            for pnt in part:
                m = pnt.M
                if m < m_min:
                    m_min = m
                    oid_min = oid
    return oid_min
    main()
It threw as result that feature with OID 5, route "B" was in the wrong direction (although a lot of testing is still required):
Before you start to use this script, please keep the following in mind:
  • This code selects the first segment (feature) based on the minimum M value
  • The first feature defined the direction, if you have 10 segments in a route and the first points in a certain direction and the rest in the other, all 9 segments would be identified as "wrong"
  • If you would like to define the correct direction based on the majority of the segments, you should determine if this is on number of features or combined length.
  • There can be infinite exceptions that could yield undesired results
ZenekS_
Thank you very much for your engagement and time you have spent on this case. I will apply and test the code. I will allow myself to contact you again in case of further questions.
ZenekS_
I have done some test with your code on my example data. I have attached the data. You will find that:
  • in my example data every segment of a given road must start with M value =0,
  • the right direction is the direction of the first segment [Segment_ID] of a given road, that is the minimum value (number) in field [Segment_ID] for a given road number [RouteName]
Below screenshot of my example roads:
The right direction for whole road indicates:
  • Road A – segment 1
  • Road B – segment 4
  • Road C – segment 7
So script should report errors:
  • Road A, Segment 2 (A, 2)
  • Road B, Segment 6 (B, 6)
  • Road C, Segment 8, 9, 10 (C,8; C,9; C,10)
For now, code indicates errors only at segment (A,2).
Please for further help.
XanderBakker
Can you share this sample set of data?
ZenekS_
