How to change the precision of a field?
2747
08-17-2016 10:02 AM
TheodoreRakel
I'm using arc gis desktop 10.2.1.  I have a versioned table with a field that is a short with a precision of 4 and tied to a domain.  It's also non nullable.  I'd like to change this field to have a precision of 6.  What's the best way to do this?  The fact that this attribute is non nullable seems to complicate things.  If I try to add a new attribute to the table with precision of 6 and non nullable, I find that the table must be empty in order to do this.  The table will never be empty.  I can get to state zero and unversion it, but it won't ever be empty.
DanPatterson_Retired
so creating a new field and just copying the results over in the field calculator or from the original source is out of the question I guess as well, but in any event, here is what you can modify in a geodatabase
Alter Field—Help | ArcGIS for Desktop
Modifying field properties—ArcGIS Help | ArcGIS for Desktop
why are you reluctant to delete it and do it again? or am I missing something
TheodoreRakel
There are over 200,000 records in the table.  I don't want to delete the attribute.  The reason to change the precision is because the domain the attribute is tied to is getting new codes that are 6 characters long.
