How do I combine multiple polygons in the same shapefile?
29703
05-13-2013 01:19 PM
JohnNovi
I have a shapefile for LA county with all the cities in it but the cities are comprised of multiple polygons.  I want to combine all the polygons for each city into a single polygon for each city in the same shapefile and I can't figure out how to do that.
JohnNovi
I used dissolve and it worked
jeffmcleroy
You can also go to the Editor drop down and click merge
SabrinaKlein
Hey all,
   What if I have a layer, say slope that one of the slope values has been converted into a polygon file. That file has thousands of fields of separate polygons. Dissolve crashes the computer.
Anyone have another alternative?
Much thanks,
Elvenlotus
Zeke
Honored Contributor
Dissolve it in parts, then dissolve the parts together.
