Would you have an idea which method is more appropriate for such image without NIR.
Then this method will not work. It requires a NIR band.
The image has only Red-Green -Blue Band...
mosaic of several images into an orthophoto.
@Luke can this be used for aerial images that has online RGB bands..
foreach b, bindgen(6) dobegin ^ % Syntax error. At: C:\TEMP\deglint.pro, Line 10 % 1 Compilation error(s) in module $MAIN$. % No valid main program present.
the algorithm is valid only for submerged pixels
nirs=samples[*,*,7] nird=data[*,*,7] d=size(nirs,/dim) i=where(nirs gt 0) o=where(nird eq 0) m=min(nirs) out=0 help, m foreach b, bindgen(6) do begin band=samples[*,*,b] r=linfit(nirs,band) band=data[*,*,b] deglint=long(band - r[1] * (nird - m)+0.5) deglint=0 if size(out, /n_dimensions) eq 0 then $ ;Image stack doesn't exist yet out=temporary(deglint) $ else $ ;Concatenate image to stack out=[[[temporary(out)]],[[temporary(deglint)]]] endforeach out=[[[temporary(out)]],[[data[*,*,6]]]] out=[[[temporary(out)]],[[data[*,*,7]]]] end
% Syntax error. ENVI> .r C:\Temp\Glint.pro foreach b, bindgen(6) do begin ^ % Syntax error. At: C:\TEMP\Glint.pro, Line 12 % 1 Compilation error(s) in module $MAIN$.
.r <path to>\<script>.pro
.r C:\Temp\deglint.pro
nirs=samples[*,*,7] nird=data[*,*,7] d=size(nirs,/dim) i=where(nirs gt 0) o=where(nird eq 0) m=min(nirs) m=nirs m = m[(sort(m))[5 * N_ELEMENTS(m) / 100] ] out=0 help, m foreach b, bindgen(6) do begin band=samples[*,*,b] r=linfit(nirs,band) band=data[*,*,b] deglint=long(band - r[1] * (nird - m)+0.5) deglint=0 if size(out, /n_dimensions) eq 0 then $ ;Image stack doesn't exist yet out=temporary(deglint) $ else $ ;Concatenate image to stack out=[[[temporary(out)]],[[temporary(deglint)]]] endforeach out=[[[temporary(out)]],[[data[*,*,6]]]] out=[[[temporary(out)]],[[data[*,*,7]]]] end
