Get List of all tables?
3655
06-28-2013 09:22 AM
AdrianaCalleja
Hi!
I'd like to know, how could I get a list of all my layers contents in SDE?
Regards,
Thanks in advance.
aecalleja
WilliamCraft
From the RDBMS directly, you can use the following queries:
To get a list of all tables registered with the geodatabase, use:
select table_name from sde.TABLE_REGISTRY;
To get a list of all layers (i.e., all GDB-registered tables which have a spatial column) within SDE, use:
select table_name from sde.LAYERS;
If you are wanting to know more spatial-specific information, the following Python script has worked for me (substitute your own info):
import os, subprocess, arcgisscripting, string, sys, os
gp = arcgisscripting.create(9.3)
gp.workspace = r"C:\Users\User1\AppData\Roaming\ESRI\ArcCatalog\test.sde"
server = 'server'
def describeFeatures(sdeWorkspace,logWorkspace, logName,instance,user, psswd):
    logfile = open(os.path.join(logWorkspace, logName), 'w')
    datasets = gp.listdatasets("","")
    for dataset in datasets:
        gp.workspace = sdeWorkspace + os.sep + dataset
        for fc in gp.ListFeatureClasses():
                args = ['sdelayer', '-o', 'describe_long', '-l', str(fc) + ',SHAPE','-i', instance, \
                       '-u', user, '-p', psswd, '-s', server]
                p = subprocess.Popen(args, stdout=subprocess.PIPE)
                output = p.stdout.read()
                logfile.write(fc)
                logfile.write(output)
                logfile.write("\n")
                print fc, output
    logfile.close()
if __name__== "__main__":
    #connection to database
    sdeWorkspace = gp.workspace
    logName = "FeatureInfo.txt"
    logWorkspace = r"C:\Users\user1\Documents\python\DescribeFeatureClasses"
    instance = 'esri_metrorep'
    user = 'sde'
    psswd = 'sde'
    describeFeatures(sdeWorkspace,logWorkspace, logName,instance,user,psswd)
VinceAngelo
Esri Esteemed Contributor
This question is quite confusing.
Do you want a list of tables or a list of layers?  Or do you really mean
"feature classes"?
What do you mean by "layers contents"?
In what environment do you need this list? Shell script? Python? C# VB? SQL?
What database are you using?  Which version?  What version and service pack
of ArcGIS?
- V
WilliamCraft
server = 'server'
                logfile.write(fc)
                logfile.write("\n")
                print fc, output
    logfile.close()
    user = 'sde'
    psswd = 'sde'
AdrianaCalleja
server = 'server'
                logfile.write(fc)
                logfile.write("\n")
                print fc, output
    logfile.close()
    user = 'sde'
    psswd = 'sde'
Tanks a lot!
