Geodatabase Toolset (GDBT) for ArcGIS v.10
8817
37
07-19-2010 11:24 AM
RachelBrowne
I heard a rumour at the ESRI International conference last week that there is no Geodatabase Toolset for V.10.
Could ESRI please confirm this and if this is indeed the case, how can we get this reinstated for the new version?
This is a toolset that we depend upon in our everyday management of SDE and if it is not available will significantly impact upon our plans to upgrade!!!!!
JohnMeza
Sorry for the late reply.
Did you have any install problems?
The User Information tab uses:
-Microsoft FlexGrid Control 6.0 - MSFlxGrd.ocx
-Microsoft Windows Common Controls 6.0 - mscomctl.ocx
use regedit.exe, at the top level (Computer) search for MSFlxGrd.ocx and mscomctl.ocx?
TonyBoehm
Using regedit I did not find MSFlxGrd.ocx.  mscomctl.ocx was found under HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows/CurrentVersion/Installer/UserData/S-1-5-18/Component
JaniceSutherland
I tried to install GDBT for Version 10 this morning and am getting erros when I run from ArcCatalog
The install showed no errors and the tab is visible but popups say:
SpatialIndexView.Class_Initialize 429 You do not have an appropriate license to use this functionality.
and
You are not licesned for .
Use the ArcGIS Administrator to view the software availability, change the license manager, or switch the ArcGIS software product.
why would I be getting this message?
Both mxflxgrd.ocx and mscomctl.ocx are in c:\windows\system32\
I am running XP Professional Version 2002 Sp3
JohnMeza
What type of ArcGIS Desktop license do you have?
deleted-user-zpcJw1u0IXiO
I'm also getting the SpatialIndexView.Class_Initialize 429 error. For me it is soon followed by a License error: "You are not licensed for Geodatabase Editor". I don't even know what that is. Why is GDBT not working properly? I'm running ArcEditor 10.
Robert_LeClair
Esri Notable Contributor
By chance did you have GDBT Toolset from 9.3.x installed on the machine?  If so, try uninstalling GDBT Toolset 9.3.x and tehn see if you're able to run the newest 10 version.
Regards,
Robert LeClair
Esri-Denver
ScottBateman
GDBT is great - just installed for 10.0 SP2 after upgrading from 9.3.1 SP1
Initially I was getting the same 429 error and I did have 9.3 GDBT installed.  After uninstalling the 9.3 version, my GDBT tab disappeared from ArcCatalog.  I then uninstalled the 10 version also and re-installed.
After that all seems to be working, Thanks!
Note that the 10.0 version I installed showed up as "GDBT-ArcCatalog" without any indication of the version number in my Add/Remove Programs on Windows XP.
JoanneLoh1
Where can I download the GDBT for ArcGIS 10? I tried http://www.esri.com/software/arcgis/extensions/gdbt/index.html but it says that the Page Was Not Found. Is there any updated link to download this?
MikeYoung1
I really really love this tool!!! I want more!
