Fragstats 4.1 - How to import results back into ArcMap?
6944
01-16-2013 10:59 AM
KarenLeu
I am trying to figure out how to take my output from Fragstats and import it into ArcMap, where I can create a raster map of my results.  I've tried two ways of going about this, but am running into problems on both fronts.
Firstly, I tried the straightforward method of inputting an Esri Grid layer into Fragstats, which successfully gives me a .patch that I can open in Excel.  The .patch contains the attribute PID (Patch ID) which I would join to an image also containing those PID values.  So, I go back to Fragstats and run the analysis again, this time checking "Generate patch ID file".  I get following error: "Cannot create ESRI grid".  I am able to run the same layer through the Local structure gradient (moving window) analysis, which successfully generates a Grid output, so I don't understand why it can't do the same at the Multi-level structure.
Next, I tried inputting a raw ASCII layer, checked "Generate patch ID file", and got my file ending in "id8.asc".  I converted this file to raster and am able to view it as an image, but cannot access the Attribute Table.  How could I then join this raster with my .patch results?
Any suggestions are greatly appreciated!
deleted-user-3rTxRfVTcNm-
Hey Karen,
Have you found a solution for this? I'm having the same problem at the moment, how to import .class, .land elements into ArcGIS so that I can make a join to another table.
Jorge_AntonioGomez_Diaz
Do you find the solution? I also have the same problem.
NeilSangSLU
The "Save Run As" button exports results as a "CLASS" file. If you open that in Notepad you will see it is actually just a CSV.
NeilSangSLU
p.s. "class" is for class metrics, the same applies to others e.g. a landscape metric output has the extension "land"
