Fixing attributes...from St to Street
4993
8
01-04-2016 01:10 PM
VaneiriKeme
I am trying to fix my attribute records in Arcmap.
Is there a way to do a bulk fixing, to find all my St and change it to Street?
ChrisDonohue__GISP
Here's a simple Python field calculator example:
!fieldnamehere!.replace(' ST', ' STREET')
Longer example for addressing multiple changes.  Use your fieldname instead of FacilityAddress.
def StreetSuffix(FacilityAddress):
  list = FacilityAddress.split()
  for item in range(len(list)):
    if list[item] == 'STREET':
      list[item] = list[item].replace("STREET", "ST")
    if list[item] == 'STREET,':
      list[item] = list[item].replace("STREET,", "ST")
    if list[item] == 'STR.':
      list[item] = list[item].replace("STR.", "ST")
    if list[item] == 'STR,':
      list[item] = list[item].replace("STR,", "ST")
    if list[item] == 'ST.':
      list[item] = list[item].replace("ST.", "ST")
    if list[item] == 'ST,':
      list[item] = list[item].replace("ST,", "ST")
    if list[item] == 'WAY':
      list[item] = list[item].replace("WAY", "WY")
    if list[item] == 'WAY,':
      list[item] = list[item].replace("WAY,", "WY")
    if list[item] == 'WY.':
      list[item] = list[item].replace("WY.", "WY")
    if list[item] == 'WY,':
      list[item] = list[item].replace("WY,", "WY")
  return " ".join(list)
Credit to Darren Wiens and several others knowledgeable in Python for coming up with this, which I gratefully stole borrowed.
Chris Donohue, GISP
DarrenWiens2
There is Find and Replace in Table options.
VaneiriKeme
Thanks Darren!
ChrisDonohue__GISP
Yes, this can be done in Python.  The Python code can be placed in the field calculator, or a pure Python run can be done.
Chris Donohue, GISP
JoeBorgione
Or select thuroghfare trailingtype = 'ST' and then calc thuroghfare trainingtype = "STREET"
That should just about do it....
ChrisDonohue__GISP
Chris Donohue, GISP
VaneiriKeme
Got it fixed. Saved me tons of hours.
DarrenWiens2
Now that I see this again, a more compact alternative may be (only lightly tested):
  replace_dict = {
    'ST':['STREET','STREET,','STR.','STR,','ST.','ST,'],
    'WY':['WAY','WAY,','WY.','WY,']
    for key, value in replace_dict.iteritems():
      if list[item] in value:
        list[item] = key
JonM32
@ChrisDonohue__GISP
I just wanted to thank you for posting this field calculator expression. I needed to update addresses in a single field to change all abbreviations to fully spelled out words. I used this expression in ArcGIS Pro, created a list of changes I needed, and updated over 16000 records with little issues. It worked great!! A huge time saver, and I learned some good skills from it.
Thank you!
Jon
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
