Field name length of the enterprise geodatabase tables\layers,
6691
6
03-13-2014 12:28 AM
JamalNUMAN
Legendary Contributor
I have SQL geodatabase (*.mdf) and wanted to know the maximum length the name of a field can take.
[ATTACH=CONFIG]32177[/ATTACH]
Does the name of fields of the file geodatabase take more character than the enterprise geodatabase?
Thank you
Best
Jamal
Jamal Numan
WilliamCraft
In versions of SQL Server 2008 and 2012, the maximum allowable field name length is 31 characters.
Source: http://resources.arcgis.com/en/help/main/10.2/index.html#//003n000000zw000000
WilliamCraft
WilliamCraft
File geodatabase field name length can be up to 64 characters.
Source: http://resources.arcgis.com/en/help/main/10.2/index.html#//003n00000019000000
NidhinKarthikeyan
Honored Contributor
Character limit for Field name in ArcSDE on SQL Server is 31 and Feature Class naming is 128.
JamalNUMAN
Many thanks William and Nidhin for the help
Best
Jamal
Jamal Numan
deleted-user-0W0-oLHxDjCX
The problem still persists on ArcGIS 10.4
User35489
Similar is case for Oracle Database. Length for Column name could be maximum 31 characters
