Field Calculator not working
907
06-12-2013 01:56 AM
PatrickMurphy1
Whilst in editing mode, I want to fill in data for a group of records, when I select them I change the table view just to show what I have selected, and then I right click on the field name and choose "Field Calculator". I type in inverted commas what I want in the field.
The calculate window appears for a fraction of a second then disappears. Nothing happens to the table.
The same issue has happened on two different PCs and on different layer types (Points & Polygon features)
Can anyone help
Pat
JakeSkinner
Esri Esteemed Contributor
Hi Patrick,
If the field is of type Text, you will want to wrap the text in quotes,  i.e. "data".
PatrickMurphy1
Hi Jake
Thanks for the reply.
I have been using the "" anyway.
I was able to sort it out, there is a glitch with Arc Map, what we did to get around it was to re-name the ESRI folder in Applications folder on the C Drive of the effected machines. Once re-named when you log into Arc Map it creates a new ESRI folder, once this is done the Field Calculator functions work again.
This also may help others with a similar problem
Regards
Pat
