Export PDF Question ?
1621
07-18-2016 02:18 PM
DEAF_PROBERT_68
Honored Contributor
I am trying to understand HOW does export to PDF works with or without an imagery. Export to PDF has a several options to choice from the list under the Image Compression. What is the best method to use to open the PDF quickest way to view ?  Here is shapshot of the video I capture and see if you can view it.
https://docs.google.com/a/techsmith.com/file/d/0BwOOP7VHyF_FOGlHXzZzM2Zrdkk/edit?pref=2&pli=1
Any tips ?
My computer has an Adobe Acrobat XI V 11.0.17 and it is Adobe Arocbat Pro.
DanPatterson_Retired
I don't use pdf as output for an onscreen image... I use png  small size, loads faster than an equivalent resolution.  Is there a reason you need pdf? like is it for output or for onscreen
DEAF_PROBERT_68
Honored Contributor
When you print it, does it print  exactly as PNG ?
