Excel to Table not functioning
2503
07-03-2017 06:26 AM
AncaUrsu
Hello! I am trying to convert an Excel file to Table. Worked last night, not anymore. No error code, see screenshot. Ideas?
Tags (1)
SarojThapa1
Anca,
The error could be because of mismatched fields and data type. Make sure there is no space in the beginning of each FieldName, no space between FieldNames (for e.g. not Feature Name but Feature_Name). Make sure there are no annotations such as N/A in the field values especially if that field's data type is numeric.
If possible, show us a snapshot of your excel spreadsheet.
SarojThapa1
I just noticed your excel file is in xlsx format. Save the excel file in xls format. You should have no issues provided there are no mismatched fields and data types.
BlakeTerhune
Additionally, field names cannot begin with a number.
JayantaPoddar
What version is your ArcMap?
Could you attach a sample of the excel sheet? I hope the table is simple, i.e., the first row of the excel contains the name of the fields, and no merged cells anywhere.
Think Location
