Error Opening feature Class - Unable to create object class extension COM component
5599
12-25-2013 07:39 PM
Ashish_KumarGupta
Hi
I am having 64 bit Oracle 11g R2 database server in Windows Server 2008 R2 operating System. As well as a another Application Server where Oracle Client 11g R2 64 bit, ArcSDE 10.1, ArcGIS 10.1 SP1 & ArcFM 10.1.1 has been installed.
I have imported dump data in oracle using impdp successfully then enable Enterprise Geodatabase using Database Management toolbox.
I am getting error while opening feature class from ArcCatalog / ArcMap,
Error opening feature class
[UserName.FeatureClassName]
As per my observation this error is coming in only linear feature class. Rest other feature classes are working fine.
Please suggest.
Thanks in advance.
Regards
Ashish
EmadAl-Mousa
you need to install ArcFM extension for your ArcGIS Desktop software.
This will allow you to open any feature classes that requires COM objects.
Regards,
