Enterprise geodatabase states will not compress.
8238
11
09-18-2014 06:15 AM
ChrisMathers
state_id
ownercreation_timeclosing_timeparent_state_idlineage_name
0sde2010-03-29 14:59:50.0002010-03-29 14:59:50.00000
118506"BAY\KMCDONALD"2013-12-03 15:42:41.0302013-12-03 15:43:32.8830118229
118621"BAY\DCOLE"2013-12-13 10:43:42.2002013-12-13 10:43:44.273118506118229
118869"BAY\JDOMICO"2014-01-02 07:57:54.9672014-01-02 07:57:55.583118621118229
119777"BAY\JDOMICO"2014-01-28 09:25:56.3502014-01-28 09:26:03.150118869119772
163687SDE2014-06-12 10:06:57.2432014-06-12 10:10:43.783119777163687
163705"BAY\GISINTERN"2014-06-12 10:19:07.5232014-06-12 10:19:07.593163687163687
169619"BAY\CMATHERS"2014-07-01 08:00:01.8732014-07-01 08:00:10.057163705169546
185464"BAY\DCOLE"2014-08-21 15:48:49.3202014-08-21 15:52:17.930169619185415
187638"BAY\DCOLE"2014-08-27 16:00:03.0602014-08-27 16:00:06.247185464187554
191938
"BAY\JDOMICO"2014-09-17 15:52:26.2102014-09-17 15:52:35.060187638191826
This table is the sde.sde.SDE_states in our production database. For some reason we cannot seem to compress away those states. Ive kicked everyone off the database including myself so that all state locks will be released and then compress but they just wont go away! We compress nightly and always drop back to these same states. Its a 10.1 EGDB on SQL Server 2008R2 without the SDE application server. Is there anything I can do from SSMS instead of Catalog to solve this?
MartinAmeskamp
Great, this is very helpful!
Martin
Von: Asrujit SenGupta
Gesendet: Montag, 22. September 2014 10:42
An: Ameskamp, Dr. Martin
Betreff: Re: - Enterprise geodatabase states will not compress.
GeoNet <http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo8h7SGfRSMkw-2FpvHGF9-2FW3rK-2Bvs1kL9-2FnG6jjf2NZhrLDz0M-2BrY-2By9IaziQEKVk3Hg-3D-3D_GjRFCNGdMNqdt7rSVIqdH0qHqDDgIeyIXpkS4jn6U-2Fr3fh9mo7Hp47Cmfn-2FKfkYVPSbbPhU0zRTPicqVCMlD7FbwMUYhqnW58oFK-2FGfuLhjFbREYhbLeVp97-2B4OPuop5QgN17AAVrl2OKR7ZLJc3RRKwoiuyXv-2FDV3ASGHdfGW1rb8EUJLWA0ge16kurRh3X5J-2BAFJAmD-2FBolms5qX8vH8UxKou0BP2ubOOT3yZiHq2RRYAJHAGjPZPlgAqZZ61E6-2Fulolax4O736Itd6vVxEPHFR4fN69r1gBJk8gjVR1pLorcDiIpehvZu-2BjDl-2B9THY8ed4MMtHstfZ67Wd0FUqA-3D-3D>
reply from Asrujit SenGupta<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo7A4BXwO9PY1WvQ5cXCtK48Jctg75Ycpj-2BRd4g0XdHaw-2FhL5Iztn268OrIjUiJNX1xN5Fi76SF6y469H2YweiWWwsEST8EAvfskpoJIOD98-2B_GjRFCNGdMNqdt7rSVIqdH0qHqDDgIeyIXpkS4jn6U-2Fr3fh9mo7Hp47Cmfn-2FKfkYVPSbbPhU0zRTPicqVCMlD7FbwMUYhqnW58oFK-2FGfuLhjFbREYhbLeVp97-2B4OPuop5QgN17AAVrl2OKR7ZLJc3RfBfkAYzmWn1F2y3DmROOaxyiRlKG71G-2FqdMlIdqArgCdM5RkZLF7iNjsm8xBVQvtoC1SBoSSq5L7iDF7IMfAER5O7ybk79-2F0ehG5oRj3-2FCRMrViSbvEW2CaqGge267FEdOpIr4qRfkE56H0B459fGAybcHh0ob3FW8FjOCHpYUvIBufNPGyX0bNMGfcPxjFoQ-3D-3D> in Chris Mathers - View the full discussion<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo0VQjeJBYpG9HGC8QZBT-2FEycHS0jXhbpD4TgIoOkWpQ-2BwpTkmy8L6-2BlAImfOIYLQqJQ-2FFx4hDR4Z9w1V60v0bAI-3D_GjRFCNGdMNqdt7rSVIqdH0qHqDDgIeyIXpkS4jn6U-2Fr3fh9mo7Hp47Cmfn-2FKfkYVPSbbPhU0zRTPicqVCMlD7FbwMUYhqnW58oFK-2FGfuLhjFbREYhbLeVp97-2B4OPuop5QgN17AAVrl2OKR7ZLJc3RcRmHbT838tUZDOoRm0Z7msSkejIofGMULr8jd9fj2ch0wIzP9KM%20Z69fNIrZiluS4HwELiyiDZUtAAX2gCAXo9hDYWEd-2B12IBmuve0YCD5zy936SyK3avB2Q0mzZQ0bWwzer360wj9-2BORK3-2FIe83TRUImVR7rvIRe6g9z-2Bl1ftk2vhc70wa3L5qE-2BxXtNIRRag-3D-3D>
ChrisMathers
I was searching for something else and this knowledge base article came up. I had 6 hidden versions from old replications that were unregistered that are just sitting out there in sde.SDE_versions. Their dates and state_ids were the same as the ones in the sde.SDE_states that wouldn't compress away. I used the Delete Version tool to drop them from this table safely. I did it in reverse chronological order to on the versions create date on a whim because it seemed safest, compressed, and BOOM! errant states gone. I'm hoping this will resolve some other issues I've been having. Please back up your geodatabase before you do this in case something goes haywire. None of my users have noticed anything amiss on the client end since this was done last Friday.
The table below shows the comparison of the two tables. Rows in green are versions/replicas that are current, rows in red are versions/replicas that should have been dropped but weren't. You can see that while they still appeared in sde.SDE_versions they had already been removed from sde.GDB_ITEMS. Item ID is in the name of the replica version.
sde.SDE_versions
sde.GDB_ITEMS
name
state_id
ID
Replica Name
DEFAULT
205718
SYNC_SEND_3_0
SYNC_SEND_5910_1
118506
SYNC_SEND_7110_0
118621
SYNC_SEND_8312_1
118869
SYNC_SEND_8312_2
119777
SYNC_SEND_5910_2
163687
ParcelEditing
205712
SYNC_SEND_20028_5
205591
20028
  1. SDE.ProductionToPub
SYNC_SEND_19649_4
205591
19649
  1. SDE.ProductionToFO
SYNC_SEND_9919_162
205591
9919
  1. SDE.ProductionToROK
SYNC_SEND_18851_7
205591
18851
  1. SDE.ParcelsToPub
SYNC_SEND_18848_11
205591
18848
  1. SDE.ParcelsToFO
SYNC_SEND_20450_2
205718
20450
  1. SDE.ProToFO_Supp1
SYNC_SEND_20453_1
205718
20453
  1. SDE.ProToPub_Supp1
