Editing 2007 MS Access .accdb using OLE DB connection?
981
06-21-2013 09:50 AM
MikeMacRae
Can you edit a 2007 MS Access .accdb file format using the OLE DB connection?
I have made the connection using the following:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Connecting_to_a_2007_Microsoft_Access_data...
I can add and view the tables from this file in ArcMap, but when I try to start an edit session on this table, it errors out with the follwoing 2 errors:
  • No editable layers
  • Check to see that you have the appropriate permissions
I created a .accdb file from scratch, so it is not read only.
Under the Advanced tab in the Data Link Properties for the OLE DB connection, I have set the ReadWrite option check mark and unchecked the rest and I am still unable to edit this table in ArcMap.
[ATTACH=CONFIG]25411[/ATTACH]
There isn't much documentation on the OLE DB connection in the help file other than how to connect as posted above. Can anyone point out what I may be doing wrong?
Mike
