Hello Map Vis, we are unable to license Map 3D technology for Data Interoperability, but if you already have Data Interoperability extension there is a cross-grade product from Safe Software that can add the few formats FME has but DI does not, Map 3D being one of them. If you do not have Data Interoperability extension then you can obtain FME at the appropriate license level.
I am interested in accessing the object data tables in AutoCAD Map and converting the layers into a file geodatabase with the object data as a field. Is this possible using DI extension 10.6 or only FME Workbench Map 3D Object Data'-reader?
Are you interested in accessing object data tables that are created and maintained by AutoCAD Map?
