Deleting multiple rows in attribute table (conditional, where there are 10 records of less)
4950
02-09-2022 07:44 AM
Kate_Gormley_abdn
I need to select and delete records from an attribute table where there are fewer than 10 records/rows for a particular field (shipid).  Unfortunately the data set is very large, so it's not possible to do it manually.  So wondered if there is a way of doing this via select attribute? or similar?  I'm working with ArcPro. Thanks
DanPatterson
MVP Esteemed Contributor
Are they duplicates?
Find Identical (Data Management)—ArcGIS Pro | Documentation
Delete Identical (Data Management)—ArcGIS Pro | Documentation
read carefully before you do anything... and try on a copy of the file if this is what you are after
... sort of retired...
Kate_Gormley_abdn
Maybe not quite, but will have a look thanks - the shipID is identical for lots of records, but I only want to delete where there are less than 10 records. (some may have 100's of points for the same shipid for example)
DanPatterson
You would have then summarize statistics on that field (a count obviously)  to identify those candidates first
Summary Statistics (Analysis)—ArcGIS Pro | Documentation
once found (sort descending on the count) you could then delete what you want
