Create 150 equally spaced points in a region
10086
03-15-2013 03:52 AM
GeospatialTechnology
I can create 150 random points in a region or create an equally spaces grid of points with a pre-determined distance between points.
What I'm struggling to do is create 150 equally spaced points within a pre-defined region.
Any ideas?
V_StuartFoote
Mark,
Not exactly an installation and configuration issue. And not a simple task.
But some conceptual treatment on GIS SE
http://gis.stackexchange.com/questions/6412/generate-points-that-lie-inside-polygon
Or, I'd look at dividing your polygon into equal areas and then using the centroid of each as location for your new point feature class.
In http://forums.arcgis.com/threads/50238-Divide-Polygon-in-equal-areas
they suggest using the Parcel Editor and divide by area.
Moving this to the Editing forum where you might have more response.
Stuart
MelanieSummers
Hi Mark,
You may want to look into the Fishnet Tool with the option Create Label Points checked on.
Best,
Melanie S.
