Copying domains from PGDB to SDE Geodatabase
1961
03-19-2012 10:22 AM
deleted-user-vu-LNxlFlQMX
A personal geodatabase was set up as proof of concept that has domains built into it.  Now I want to make it part of the enterprise and put it into SDE.  I can copy the tables ok but the domains don't seem to.  I was wondering how to move tables with the associated domains into SDE.
any help with this would be great!
Stephanie Magnan
TimHopper
Stephanie,
When you export the feature class (or copy and paste) from the personal geodatabase into SDE the domains should automatically come along with it.
If you copy and paste the feature class / table from one geodatabase to another, you should see the domains listed in the Data Transfer window.  In the Data Transfer window, do you not see any domains listed?
Under 'Type' you should see "CV Domain and/or Range Domain".
