convert microsation data to gdb with mslinks
2182
04-24-2012 02:33 AM
esinduran
We have a microstation data with mslink and need to convert to esri format. The problem is some data lost its mslinks but some are corretly converted. We checked the version of v8 an v7 an the problem is same it doesn't depends on the version of microstation. I attached the print screen of the microstation and Arc map with true and false.
If there is a way to convert data with mslink can you please share with me.
Kind regards,
esin
jyakypetter
Salutation to one of the the majority forum site
Here we get much awareness in it from some
Experts.
Thank you�?��?��?��?��?��?��?��?��?��?��?��?��?��?��?��?��?��?��?��?��?�..
struts2 jQuery
by Anonymous User
Not applicable
Original User: christi_nelson
Hi there,
Did you ever get an answer to this problem?  We are having the same problem.
Christi
