Convert .dwg(autocad) file to .shp file
10272
5
08-14-2015 12:15 AM
SUBHASBERA
I have a land parcel map which shows detailed landuse. It is a .dwg(autocad) file. I want to convert it .shp file with similar attributes as it is in autocad file. When I add the .dwg file in arcgis and export it in .shp its only export polygons, polyline etc..but no similar attributes with the feature. How it can be solved........advice please....
Title was edited by: Timothy Hales
JayantaPoddar
For converting CAD Annotation,
Import CAD Annotation (Conversion)
EDIT: Import CAD Annotation—Help | ArcGIS for Desktop
Think Location
RebeccaStrauch__GISP
Jayanta, Geonet is still having issues with links​ as talked about here An issue with creating hyperlinks   Until fixed, I'm finding Jim  Barry's suggestion (first comment) to work the best...just noticed several of your responses with links to help are having the issue (that is, going to help home page).
(Sorry for the off topic comment)
DanPatterson_Retired
which is why I use 10.3 links...not much different and they work
JayantaPoddar
Thanks Rebecca for bringing to my notice. I'll remember this in future.
Think Location
