codevaluedomain stored in the DBMS but didn't appear in the attribute table in arcmap
3968
13
08-02-2011 12:21 AM
ben_abdallahmhd
good morning
i have this problem:
i have designed a table that contain CodedValueDomain with UML and and I implement it in sqlserver
when i would work with this table in arcmap the list o value in the CodeValueDomain not appear.
Some idea please
thank you
ben_abdallahmhd
Thank you very much cgillgrass
ben_abdallahmhd
good morning
"In order for the domain to appear in ArcMap, it needs to be associated with the field. Can you try manually associating the domain with the field in ArcCatalog and test if that allows you to see the domain dropdown in ArcMap? "
yes i tried associate it manually and it work.
but it didn't work on the table having subtypefield.
thank you
CraigGillgrass
Once you have subtypes defined, you need to make the field and domain associations on the Subtype tab.
ben_abdallahmhd
thank you   Craig Gillgrass for your help
