Clipping .tiff image changes colors of original scanned .tiff image
5577
03-03-2011 09:22 AM
by Anonymous User
Not applicable
Original User: scheadley
I have scanned our old zoning maps that are printed on white paper with colored polygons representing the zoning classifications.  These were done in 1989 on a plotter.
When I scan them at 75dpi in color as a .tif image, they come out exactly like they look on the hard copy.  When I georeference them, then use the Data Management-Raster-Raster Processing-Clip tool, the colors come out much darker and some of the polygons are black.  Any reason for this happening?  The .TIF files are 3 bands.  I uploaded my 2 files as jpeg, but they look exactly like the tiffs.
Thanks
Steve
RobertBerger
When you run the clip tool, the tool will automatically calculate statistics that will be used for display. You can try to turn of the stretch on layer properties > symbology tab to see if that is indeed the issue.
If this is your issue you can try to remove the statistics or change that by default no stretch is used. Alternately you can turn of the statistics calculation in the geoprocessing environment and run the clip again.
Is that what you're seeing?
Robert
by Anonymous User
Not applicable
I don't think stretch is enabled on the clipped .tif.  I looked at the layer properties and it is not checked.
How do you turn off the statistics calculation before the I run the clip?
PatrickTaurman
Your screenshot shows Stretch set to Standard Deviations, so stretch is being applied.  Switch this to None, and you will see the display change.
As for not calculating statistics, go into the Environments > Raster Storage Settings and uncheck Calculate statistics when you use the Clip tool.
by Anonymous User
Not applicable
That worked!  Switching the stretch value to none.
GordonSumerling
Steve,
Be aware, if ArcGIS detects statistics have been generated when it loads an image it will automatically stretch the image for you. You can turn this off though. Go to ArcMap options->Raster->Raster Layer. Set the stretch type to None. Once you have done this then it should not stretch any images again for you.
Also, If you delete the corresponding AUX file with the image, this will remove the statistics and not do a stretch next time you load it.
Cheers
Gordon
