clipping a raster out of another raster ("doughnut" result) - using image analysis?
768
05-06-2013 11:38 AM
EmmaYoung
(cross-posted with Imagery and Raster Data)
Hi everyone-
I apologize for the fairly simple problem, but I've read several threads on the matter and even watched some videos, and I'm still not able to get what I want. What I'm trying to do is clip OUT a smaller raster from a larger one, leaving a hole where the smaller raster previously overlaid (leaving a "doughnut" shape, if you will). The only techniques I can find in ArcGIS 10 clip or mask the extent of the LARGER raster to the SMALLER one, so that I get the exact opposite result that I'm going for. I know there must be a fairly simple answer out there, but I'm getting really frustrated. I've read that the image analysis toolbar can be used, but I haven't been able to get it to work. Any help on this matter would be EXTREMELY appreciated, thanks.
Emma
TrishRice
I was about to suggest clipping it to a donut polygon as suggested here but can't get it to maintain the donut.  However if you have Spatial Analyst you could turn the donut polygon into a raster with zero values wherever you want the image removed and one values for what to keep.  Then use Raster Calculator to multiply the original raster with the clip raster.
A brute force method if nothing else works is to chop up your larger image into small pieces that go around your smaller image, then mosaic them back together.
BrentTombs
Extract by mask always works for me.
