Checking dataset (GISPRD.A4). Table (GISPRD.A4) was found in GDB_ObjectClasses, but does not exist in the database. Skipping. DBMS table not found [GISPRD.A4][STATE_ID = 19914] The index passed was not within the valid range.
It's possible to remove SDE.GDB_* rows directly, but this should only be donewith close guidance from Tech Support. I'd recommend you create an incident.- V
One option is to use sdetable -o delete to delete the tables, then use ArcCatalog to create a table of the same name, then use ArcCatalog to delete it.
This won't work always, as if there are orphaned records, ArcGIS won't allow creation of a new Table with the same name.
So creating the Table using SDE-Command line or from DBMS end and then using ArcCatalog to delete it will remove all orphaned records.
I had a similar issue where a dataset (SDE) could not be registered because a feature class that was renamed suddenly disappeared in ArcCatalog. Reading this thread was very helpful and decided to ask our DBA to add the orphaned table in SQL. Some people commented that the table does not appear in ArcCatalog and would appear the following day. While others have said that you have to refresh the SDE connection or re-add the connection.
As expected I could not see the newly added table in ArcCatalog even after refreshing the SDE connection. I had to delete the current SDE connection and add it again using the same credentials.
The table appeared in ArcCatalog and I was able to delete the table. Strange thing though is that the SDE dataset that I wanted to register was already registered as a version but could not edit a feature class ( it says I don't have the permission). I unregistered the dataset and registered it back and finally I was able to edit the feature class.
