Cannot register as versioned, cannot delete topology
856
04-07-2010 05:24 AM
KatyRich
In our geodatabase, one of the feature datasets contains 3 feature classes and one topology.  We need to make some edits on the feature classes but when I try to register as versioned, I get the message, "One or more of the selected objects does not support moving edits to base.  This option is not available".  When I click OK, I get the message, "Failed to register as versioned".   I thought possibly the topology was causing problems, so I decided to delete it, make the edits and then re-create the topology.  When I try to delete the topology, I get, "Failed to delete selected objects".  What can I do to make the versioning work, so the edits can be completed?  Thanks.
Katy Rich
GIS Coordinator
Oklahoma State Department of Health
ThomasColson
I get the same error, despite following these instructions exactly:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//006200000009000000.htm
Is there a work-around for this? I'm all patched up to the latest 10 SP 2.
