Can't see INSPIRE Layers
2404
08-08-2011 01:34 AM
by Anonymous User
Not applicable
Original User: jaykayone
Dear INSPIRE Team,
I've installed ArcGIS for INSPIRE and I have the following problem:
When I click "Add INSPIRE Layer", I choose my Geodabase.
The program runs a quick analysis and shows me an empty list of INSPIRE Layers.
The GDB Template has been successfully loaded into an Enterprise Geodatabase. The FCs and Tables are registered as versioned with the "Move edits to base" option.
The DBMS used is Postgresql 8.3 on 64bit Linux. The geodatabase works fine and can be edited with the standard ArcMAP Functions.
Why can't the ArcMap Addin find the INSPIRE Layers?
Can it be related to the PostgreSQL prefixes (Feature Class: inspire.inspire.auAdmUnitS)?
Thanks in advance
Jeff
by Anonymous User
Not applicable
Original User: caido
If Feature class has no data it won't appear in "Add Inspire Layers" wizard.
JeffKonnen
hi caido,
that's interesting to know.
I've tried adding some dummy data, but it still does not appear..
Do you know if some minimal fields have to be filled for the FCs to appear in the list?
TIA
Jeff
by Anonymous User
Not applicable
I had imported the "schema only", I've just reimported the XML Schema with the data and now I can see them in ArcMap.
Thanks, you've put me on the right track.
JeffKonnen
now that I've reloaded the XML Workspace File with its data, the dialog even shows me the empty FCs
