Can't find the scclient.ma file when install ArcSDE CAD Client ?
909
01-22-2014 10:35 PM
TaiBui
Hi everyone,
I am trying to install ArcSDE CAD Client tool for using with Microstation.
When I try to add the ArcSDE CAD Client path to MicroStation. I can't find the scclient.ma file in the scclient folder and other folder.
Another thing: I can't see the "cadclient" when chosing Interface, please see the attached file.
[ATTACH=CONFIG]30748[/ATTACH]
May you help me ?
Thanks and regards,
Tai
JacobHaney
Hi Tai,
I think you didn't install properly that's why you're facing this kind of issue. If in your system other CAD version installed then the installation will not proceed. You've to remove the existing CAD client version through control panel. After that Install ArcSDE CAD Client tool once more.
At the time of installation, follow all instructions on your screen properly.
I hope it can help you.
