Can I safely add a column to a file inside of a feature dataset that is versioned?
638
11-23-2010 03:30 AM
BrandieYalniz
The feature dataset is versioned with several people making edits to 2 different feature classes.  The feature class that I need to add the new column(s) to does not have anyone editing it.
Can I add the column without destroying other people's work?  Also, if it can be done, should the changes be made at the DEFAULT level?
Or should I just completely take it out of the versioned dataset?
Thank you!
