Calculating Topographic Exposure with Raster Calculator
1783
03-14-2014 06:13 AM
MaryLynn_Tobiasz
I need you help trying to calculate Topographic Exposure (TOPEX) on a DEM in ArcGIS.  I am trying to figure out wind exposure on a DEM with 25m cells.
There is a great blog post where someone explains how to do it but he uses GRASS. http://jamiepopkin.blogspot.ca/2011/01/calculating-togographic-exposure-with.htmlI thought I would be able to put the same equation into ArcGIS Raster Calculator but it says the equation is invalid. I've tried playing with it as much as I can but I can't seem to make it work.
His first equation is:    r.mapcalc incl4north = "atan(((dem - dem[4,0])) / ((25 * 4)))"
And then he goes on to string a bunch of them together
[ATTACH=CONFIG]32197[/ATTACH]
Does anyone know how the equation should appear in Raster Calculator in either ArcGIS or QGIS?
I am super grateful for any assistant that anyone could provide
DuncanHornby
MVP Notable Contributor
The reason why your equation is failing is that you are using the syntax that grass uses.
dem[4,0] means nothing in ArcMap and is an invalid syntax.
Reading the web page you linked to it seems that this syntax is all to do with calculating some off-set.
I'm not sure if this is a red herring as my raster processing skills is not as good as my vector skills but I know you can shift a grid using the Shift tool. Or maybe someone can suggest some whizzy way of using focal stats?
Duncan
