calculate volume of sinks - generate after raster
572
05-18-2010 01:01 AM
MaikusMensl
Dear GIS'ler,
I have a xyz data set (3D data) in shp format. The data represents a small plot of 1.50 X 2.50 sqr meter. The plot ist not plane - the hole plot is about 20 cm sloped. On my plot there are an awful lot of very small sinks at different elevation (z)levels.
Now I wonder how I can calculate the volume of all sinks on my plot.
So far I converted the shp data into raster data. Now I want to use the cut/fill procedure to calculate the volume of all sinks. My problem is to generate the after raster for that operation. What I need are planes above all my sinks at the edge of each sink (pour point), right!? What I did so far was to create contour lines and convert them into raster data. The Problem is, there are also contour lines in the sinks and I only want them on the the edge of each sink. To cut them by hand would be labour-intensive because of a very heterogene structure.
Is that approach right to generate the after raster for the cut/fill operation? Or is there another easier solution. Hope so.
Many thanks in advance.
Cheers,
Markus
