Auto apply Shape.STLength measurements to new Shape_Len field
1898
04-18-2024 05:57 AM
wgreen90
I've noticed the Shape.STLength field does not get brought over into the enterprise portal after publishing. I have created a new field named Shape_Len and performed a field calculation where Shape_Len = Shape.STLength and it populates the new field successfully and appears in the portal when publishing. The issue I'm trying to figure out is that when I create a new line segment my new field doesn't auto populate similarly to the Shape.STLength field, it remains <NULL>. Is there a way to auto populate my new field whenever a new line segment is created or modified with the same value in Shape.STLength?
Thanks
MarceloMarques
@wgreen90
Introduction to attribute rules—ArcGIS Pro | Documentation
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
RhettZufelt
MVP Notable Contributor
I was having the same issues trying to do a dashboard in AGOL.  The Shape.STLength field isn't actually in the enterprise table, but is somehow connected 'on the fly'.
There is probably a better way, but to overcome this, I created a view in SQL Server, then registered that view with the database.
CREATE VIEW [dbo].[_WatermainsView]
AS
SELECT         Material, Owner, Shape.STLength() AS Length, Shape.STLength() / 5280 AS Miles, Shape, OBJECTID
FROM dbo.WPRESSURIZEDMAIN
I then load that view instead of the featureclass for my services.
This example will not only have a column named "Length" that is in map units (equal to what the Shape.STLenght() is) as well as as a column named "Miles" that is miles so I don't need to do the convertion in the dashboard or popups.
R_
VinceAngelo
Esri Esteemed Contributor
The third option is an ON INSERT OR UPDATE trigger to preserve the contents of the actual column.
- V
