ArcMap won't open any other kind of file except .shp
6786
17
09-01-2016 05:44 PM
KaylaniMendez
I'm trying to create a new level of data on my map but ArcMap will only recognize .shp files, how can I fix this? I already decompressed the entire .zip folder.
KaylaniMendez
Thank you so much!
DanPatterson_Retired
Hope it worked out
NeilAyres
Patience of Job, Dan_Patterson
KaylaniMendez
Yes it did! Thanks. I'm just really new at this, currently on an independent study course on this because nobody else signed up for the class. It's a nightmare
NeilAyres
Well after this, you can see what a nice bunch of people we GISsy types really are.....
I hope you continue your studies and get into GIS in a little more depth.
KaylaniMendez
I hope so too! Thanks!
If you are with an educational organization, the person in charge should/might be able to get you access to a large number of esri training courses for free.  I know we do at our university and we make them available to all students.  They cover all levels of expertise and a huge number of areas of interest.  You should look into this possibility, otherwise look for free resources under Services and Support on the main banner.  Good luck
