ArcMap Drawing Errors: A Column was specified that does not exist
13266
7
09-26-2017 09:39 AM
Peter_J_Armstrong
Hello there,
I am in need of assistance. I deleted a "column" in the attribute table and this column was essentially tied to everything. I realized immediately that I had made a mistake so I closed ArcMap without saving changes in order to not save my said mistake. I reopened ArcMap and I believe the column is there...however I am now receiving an error message "ArcMap Drawing Errors: A Column was specified that does not exist."
Can anyone provide insight as to what i need to do to restore the former configuration? Your insight and assistance is greatly appreciated!
DanPatterson_Retired
Not clear from your description, but I assume you opened the table to confirm whether the fields is there or not? And were you in edit mode or not? since there is usually a warning on field deletion outside an edit session
Peter_J_Armstrong
HI Dan,
Yes, I believe the field is there…
Peter_J_Armstrong
Good question regarding editing mode...not entirely certain, but I do not recall getting a warning about deleting the column..
right-click on the layer, select Open Attribute Table... it is either there or not.  If it is not, then there is no undelete once the project is closed, but you can copy your attributes over from a backup if you have one
Peter_J_Armstrong
Thanks, Dan. So I can confirm I did indeed delete said column and it is not there. How would I go about adding it back? Since it is only one column/attribute? I do have an Excel sheet with the data....
You need to 'join' the data back with the table.  Several variants on how to do this
http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/join-field.htm
http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/add-join.htm
and the obvious table contents shortcuts, if you have found them..
You will need a 'key' fields (an ID field for instance) to provide the joining mechanism.  Read the details before trying this for the first time,
Peter_J_Armstrong
Thank you, Dan! I will give it try.
