ArcMap Crash saving edits to ArcSDE-Oracle
1176
5
05-06-2010 07:13 AM
MilesWacker
Product: ArcMap 9.3.1, ArcSDE 9.3 on Oracle 10.2.0.1
We have a ArcSDE-Oracle geodatabase and are performing concurrent editing on versioned data, editing the default version directly.
Some users are experiencing ArcMap crashing when saving edits.  It is hard to reproduce but one user in our group has it happen often, other users once or twice, and some never (6 users).
Attached is the dump files from the user that crashes often.  Any suggestion will be helpful, we have reset normal.mxt templates.
anthonysanchez
10.2.0.1 is an unsupported release for arcsde 9.3x.  I'd start there.+
Good luck.
MilesWacker
Not sure if that version is correct, SDE reports:
Oracle 10g build 508
VinceAngelo
Esri Esteemed Contributor
The ArcSDE build doesn't really have anything to do with the Oracle release --
you uneed to upgrade to at least 10.2.0.7, or ArcSDE will not function reliably.
- V
Bahaa_Al_DinKhleifat
same problem
VinceAngelo
Same solution -- Use a supported database (you should be into Oracle 11g and ArcGIS 10.1 by now).
