arcgis 10.x and autocad : DWG not updating in ArcGis ?
3166
04-02-2016 12:21 PM
chrisnoname
Recently (it's been happening for about a month) when I open an aucocad drawing (DWG) in ArcGis, I see the old polylines that were erased in an older version of the same drawing and replaced with new ones.
When I open that same DWG with an autocad viewer (Autodesk DWG trueview) I only see the new line but with ArcGis I can see both the old and the new line.
What could do that ? Is there anything on my end that I could do to prevent that from happening ?
I've been opening DWGs for a long time and up until recently, it has never happened to me.
I should note that the DWG is being updated in Autocad over and over for the past month under the same name. So it's a "save over" the old version.
Could that explain it? It's really like the drawing keeps the "memory" of the last version.
I don't know if I'm being clear enough but I hope someone will be able to help.
Thank you for your time
