ArcGIS 10.3: how to create Geopackage with raster tiles
9578
14
01-14-2015 01:47 PM
KIMIWATANABE
Hello, everyone!
ArcGIS now supports the 1.0 OGC GeoPackage format.  I am wondering how I can create geopackage files with raster tiles. Could you direct me to some documentation for it, please?
Thank you for your help in advance & happy mapping!
Tags (1)
juliaharrell2
Lance - is there any estimate for when this compliance issue is expected to be resolved about not requiring tile/zoom levels to start at 0 ?
LanceShipman
We are currently working on this. I may be able to provide an estimate next week.
Lance
JoshuaBixby
MVP Esteemed Contributor
Lance Shipman‌, I noticed in My Esri that the following bug was closed this past January as "Not in Current Product Plan."
#BUG-000090526    If a geopackage is input with zoom levels not beginning with 0, arcpy.MakeRasterLayer returns the following error, "Failed to execute. Parameters are not valid. ERROR 000865: Input raster: does not exist."
Even with the latest Desktop releases, I cannot get the OGC GeoPackage Whitehorse download to load properly.  In ArcMap 10.5, I get:
ERROR 000860: Input raster: is not the type of Composite Geodataset, or does not exist. Failed to execute (MakeRasterLayer).
In ArcGIS Pro 1.4, I get:
ERROR 999999: Error executing function.  Failed to execute (MakeRasterLayer).
I find the different error message interesting/odd.
Seeing the bug was closed and the issue still persists, did Esri just decide not to work on it?
UPDATE:  See response below to Lance S. for update.
LanceShipman
There have been a lot of changes in the geopackage support since BUG-000090526. The raster2gpkg tool for 10.4 and 10.4.1 was updated in October 2016 base on the changes included in the 10.5 release.
Are you talking about the image located at:
https://portal.opengeospatial.org/files/63156
JoshuaBixby
Yes, I was/am talking about the GeoPackage referenced at the link you provided.
Regarding the new errors, ERROR 000860 & ERROR 999999, my bad.  I went back and tested it again, and it works.  I used the wrong syntax when I first re-tested it.  Using the correct syntax, it works in ArcMap 10.5 and ArcGIS Pro 1.4.  I struck through most of my previous comment but didn't delete entire comment because bug status still an issue.
Seeing that it works, and whatever issue was resolved, I guess this is really a My Esri and Esri Support problem since the issue that caused the bug to be logged has been fixed but yet the system says it isn't and won't be fixed.  I will inquire with Esri Support regarding the conflicting information in My Esri.
