Analyse data geolocated in different spatial partitions (polygons + pointss)
3011
11-03-2021 03:46 AM
brollobarbara
Hi everybody!
I have to analyse data referred to different spatial partition of a city: some data belong to ZIP code areas, others to neighborhoods, others to an administrative division of the city, others are in a sort of grid.. They overlap in certain points but have different shapes.
How do you recomend me to procede?
My first idea is to chose a partition (the one that has bigger areas) and "convert" some partitions into  it (es. spatial join or through centroids relocation). Another idea is to convert everything in a grid and then analyze not considering areas but more buffer zones.
Any suggestion is highly appreciated, thank you!
DanPatterson
MVP Esteemed Contributor
What is the attribute you are trying to analyze?
Is the same attribute being collected using the different spatial collection methods?
... sort of retired...
brollobarbara
Hi Dan, thanks for answering.
I am analysing socio-demographic patterns in the city. Different layers, with different territorial partitions, have different attributes like: presence of foreign students, hotels, price of houses, ecc.
What do you suggest? Maybe put all in grids is the best?
Thank you for your answer 🙂
DanPatterson
I would pay some attention to how you are going to have to represent some of the data since some spatial patterns may need to be aggregated while others may need to be potentially over-represented.
